Categories
Platforms
Content
That is no programmer at all. It is a USB-to-serial converter to be used with e.g. Arduino boards.I have a ch341a
As far as I can see this programmer will need an additional adapter to accept the FLASH chip in its TSOP case.FlashcatUSB XPORT programmer.
I thought so, but a dedicated programmer will be comparatively expensive in any way.they are a little bit more than I wanted to spend.
Where would you get the Image for the new FLASH chip? The firmware package you can download for your router is usually not suitable for direct programming into a FLASH. The existing firmware in the router will interpret the data from the downloaded firmware file and program the FLASH accordingly (and possibly set some configuration data within the MCU).I was hoping to update the programming on the new chip to a more recent firmware.
